To: sturat
Posted: 02 Dec 2004 12:05
Subject: coil
Hear's what 00sid told me.
00sid wrote:
right i have fitted the coil and the car is running.
the wiring was abit tricky had to check the drawing and test the wires on the car.
the plus feed wire to the coil is the small green and yellow one this has to go to the new 0.8ohm resistor and then to the coil.
the ground switching wire is the larger black with red stripe wire ( this goes to the ecu ) and then to the coil.
hope this helps
hope this helps rob
_________________
Please after reading one of my post's DON'T SLASH YOU WRIST'S OR CHANGE YOUR USER NAME I MIGHT FEEL GUILTY FOR AND HOUR OR TWO.
hope that helps matey
i just mounted he resistor on the old coil mounting. little green and yellow wire goes via the resistor to the positive + mount and the black/red one goes straight to the negative - mounting.
dead easy, you' ll need a decent wire thickness for the earth wire if you extend it like i did and i used the supplied one for the positive feed. mines working fine
opened my plug gap up to .85mm at .98bar and it runs very nice indeed. opened em up monday and iv caned 3/4 of a tank since then BOOTING it up 'n' down my private bit of strip :twisted: with no problems.
let us know how you get on? i reckon your gonna be a very happy puppy
