will do matey
rob
rob
Nope standard nissan 5hite That's why I'm looking to change itSi.. said:Rob,
shouldnt you already have a better than std coil, :?:
just a pal of mine runs Motec and his std coil was ditched when he got the motec put on.
zia said:what wrong with standard sh**e then!!!! with turbo plug gaps being small you don,t really need huge amount of power to make the spark jump.
zia
GINGA said:If you have a more powerful coil then in theory you should be able to run a bigger plug gap which gives smoother running, better fuel consumption etc etc
Rob I take it this coil lead is 8.5mm? Can they not make a 10mm one? How much was it...?vpulsar said:Magnecor are going to make me a new KV85 coil lead for my new MSD coil, 2 foot long so I can mount it away from the heat of the engine .
http://www.magnecor.co.uk/
rob
Ps if anybody want's a set of 10mm leads thet will make you a set to order 8) .
Rob I take it this coil lead is 8.5mm? Can they not make a 10mm one? How much was it...?[/quote]JU5TY said:Ps if anybody want's a set of 10mm leads thet will make you a set to order 8) .
