ALL PPG gearsets for the Pulsar are STRAIGHT CUT
You can have either DOG or SYNCRO as is your wish
Dog is no clutch, Syncro is like standard.
Helical is like standard, Straight cut gears whine.
Theres info on my site here
www.apexperformance.co.uk/ppg
and here
www.ppgearbox.com.au
The Austrailian site aslo has some funky flash stuff to show you how stuff works
				KevD said:
			The listing I have is below, the PPG listing states helical if it is - I'll double check but I'm pretty sure they only list a striaght cut gear for the GTiR
Nissan N14 GTiR (Final Drive) £1,075.21
Nissan N14 GTiR 1/2 (dog box) £1,710.56
Nissan N14 GTiR 3/4 (dog box) £1,392.89
Nissan N14 GTiR 5th (dog box) £995.80
Nissan N14 GTiR 1-5 (dog box) £3,854.84
Nissan N14 GTiR 1/2 (syncro) £1,445.83
Nissan N14 GTiR 3rd (syncro) £519.29
Nissan N14 GTiR 4th (syncro) £519.29
Nissan N14 GTiR 3/4 billet selector fork £333.98
Straight Cut Gearset
The Straight Cut gear design incorporating our PPG distinctive tooth profile provides even more strength than our already ultra reliable helically cut gearsets. One of our more popular items ... the Subaru WRX straight cut set can be found in vehicles with over 600hp. A far cry from the standard power output from factory and certainly a power level that needs a gear box of phenomenal strength to get power to the ground without failure.
Straight cut gearsets are relatively noisy in operation and have an inherent whine to them. This is due to the meshing of the teeth when the gears are rotating.
The meshing of straight cut teeth gives total contact along the tooth at all times which gives the straight cut tooth its added strength over the helically cut tooth .
Helically Cut Gearset
PPG helically cut gearsets are our most popular product. Mainly used to transmit extreme power to the road in highly modified street cars. They are usually purchased by those wanting less gear noise than a Straight Cut gearset. Our Helical sets do produce slightly more gear noise than a standard factory gearset as a result of a purely motor sport based gear design which makes necessary compromises in regards to gear noise, to achieve uncompromised strength.
Synchromesh Engagement (Synchro ‘box)
PPG Synchromesh Gearsets enable factory style gear selection to be incorporated into your Helical or Straight Cut Gearbox. The Synchro’ Box is mainly used for street applications. At PPG we make the Synchromesh rings and hubs considerably stronger than factory components and incorporate our high quality materials and heat treating processes into the finished product ensuring durability you can rely upon for years to come.
Dog Engagement (Dog ‘box)
Essentially a “race only” style of gear engagement, this has become more and more popular for highly modified street cars. Dog Engagement gear selection is available on either Helical or Straight cut PPG Gearsets for a variety of applications. And a combination of Dog and Synchro’ is available on our Subaru sets.
Providing fast, positive gear selection, with or without the use of clutch. The PPG Dog Engagement gear sets are undoubtedly the strongest and most “user friendly” on the market. However it should be pointed out that Dog Engagement Gearsets require fast, firm gear selection and are quite noisy on each gear change
