tubular manifold
johnny gtir
just examples top one as said x4 two bolt flanges second slash cut holes or the last option is normal round holes or you can make them oval and alot bigger all supposed to help stop warping by allowing for expansion. dose it help/work was my question ? quiet a few exhaust fabricators use the methods. before someone says the second flange is for ref only not to fit a pulsar
RO_SUNNY
AAha....now i get you.
The bolts that go in the head are metric 10 and the holes from the flange will be metric 12.
Also all surfaces will be flatened out before delivery of the complete manifold....and I will also make a support in order to sustain the weight of the turbo.
But....as I previously said...all manifold will have warranty and all the problems are to be dealt with accordingly.
Regards,
Bogdan
RO_SUNNY
I had some collector angle issues....andn I got mad about it and made another one with less angle.
The flange is tappered on the inside to let the gasses flow easily
you got any prices in mind for these yet bogdan?
i may need one making up but instead of a bolt on t3 flange would need a slip on type round connector direct to downpipe
Looking good, is that t25 or t3? And could you build 2 waste gate ports at 44mm on either side of the turbine flange that would avoid the compressor , also can the turbo be moved away from the block and gearbox when on the car with say a gt35 fitted?
RO_SUNNY
That is an t25 flange .....because I said that will be stock position and for a stock frame turbo.
I have also made some 6 mm spacers for the ones which will use a bigger turbo (let's say a gt35)
Yes I can put 2 wastegate's 44m.....one on each side of the collector.
But....for now I will make this one an see how it's going.
Cheers Danny,
Bogdan
RO_SUNNY
Collector 100% welded now
All ''jigged up'' and ready for the runners to ''blend in'''
Full penetration welds
vpulsar
Looks very nice mate don't forget to leave access to the bolt holes my first stainless manifold was a right bastard to get at a couple of the bolts.
