Pauter X-Beam Con Rods - Feedback??
Hi,
I've been a silent member for some time and found all your experiences and guides very useful. After 3 years trouble free my gearbox spat its dummy out so I'm building the whole car up into, hopefully, an unforgiving monster. With minimal machanical history its going to take me many many months - it took me few weekends (I work away a lot) just to get the engine out (single handed with 2 trolly jacks + skateboard :-D )
I've tried the search with no luck.
Does anyone have any feedback on these con rods? I found them on Eric's ebay store. I had originally planned to use Eagles but feedback was mixed and didn't want to take the risk. The advertisment states:
This listing is for (4) brand new Pauter X-Beam Connecting Rods for the Nissan SR20DET engines found in the RNN14 GTIR Pulsar.  These rods are for use with the GTIR 19mm wide Rod Bearings.  All other SR20DE & SR20DET engines use 17mm wide rod bearings.  We have those available as well.
Engine: Nissan SR20DET
Pin Diameter: .894"
Big End Bore: 2.008"
Length: 5.360"
Big End Width: .856"
Weight: 560 Grams
Rod Bearing WIdth: 19mm (GTIR Specific)
Part #: NIS-220-510-1361F-GTIR
These rods use an X-Beam style rod that is different from the typical "I", "H" or "A" beam.  These X-Beam rods are very strong and resist cracking due to the X-Beam design.  These rods are made to withstand the force from the highest horsepower & highest RPM engines.
Specifications:
- <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">E4340 vacuum melt chrome moly forging <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">CNC machined <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">Heat-treated to Rockwell C36 <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">full coverage shotpeened <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">end-to-end balanced in sets <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">Pauter 220kpsi tensile strength MSP220 steel, J-formed, rolled thread racing rod bolts standard <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">Aluminum-bronze wrist pin bushings (standard)
- EDM pressure-fed oiling to pin (available at $45 per rod)
http://cgi.ebay.com/ebaymotors/Pauter-Rods-X-Beam-Nissan-SR20DET-RNN14-GTIR-Pulsar_W0QQcmdZViewItemQQcategoryZ33623QQihZ008QQitemZ180173126537QQtcZphoto
Spec of R before GB failure:
Full HKS exhaust (tubby elbow back)
Decat
Uprated injectors
Exedy clutch and cover
Exedy lightened + balanced flywheel
Apexi Power FC ECU
Apexi AVCR (1.2Bar)
Other parts ordered so far in case people ask:
JUN titanium double valve springs
JUN valve guides
JUN Retainers (type 1)
TOMEI (270) cams
Greddy rocker arm stoppers
JE 87mm top coated pistons
ACL race series (calico coated) rod, main, and thrust bearings
Cometic head gasket
ARP head & crank studs
Items yet to be ordered:
Rods
Water pump
Oil pump
Quaife gear set
3076 tubby
Starter recon
Alt recon
Transfer recon?
injectors
MAF
+ other ancillaries (massive list)
Thanks in advance,
Jonnie
