was this with water cooling too?
Yes water feeds were connected ;-)  There were no oil feed issues either as I disconnected the feed pipe from the turbo and cranked the engine and it filled a cup pretty quickly. The restrictor in the turbo was all clear too.
This is the heat shield Danny is talking about, the bearing that collapsed sits about 10mm behind this.
This is the bearing from the compressor end of the turbo with the bearing cage still intact.
This is the bearing that collapsed, the plastic cage had gone rock hard from the heat.
And I took this picture of the restrictor that's built into the turbo just to clear up the argument that you don't need to fit one.
