RishiGTiR said:
What sort of money were you thinking..?
at least double that.
Billet Engine(2L - 2.3L) - £4000
Drivetrain - £6000
Suspension & Diffs - £3000
Turbo and Cooling - £2000
Management and Fueling - £3000
Wheels & Tyres - £1000
Interior Gauges, Seats and Harness - £1000
Total Cost - £20,000
Result - 500bhp to 900bhp Monster depending on the desired spec with the above build costs..
for starters theres approx £700 worth of nissan parts to go in a fresh engine, oil pump £340 (assuming the standard pump is good enough of course) timing chain, tensioner and guides is approx £200, gasket set is £180 iirc, pistons and rods are going to be approx £700 at the cheapest, stroker crank minimum £1000, headgasket average £140, liners £200, bearings £100ish (£3560 so far for parts) then you have the labour for machine work to the block including liners £900, cams, pullies, springs, retainers approx £1000, forget the standard valves doing 900bhp so you'll have to go custom, new guides and extensive headwork at least £1000. All the arp stuff as a bare minimum £200, On top of all that if you cant build it yourself a minimum of 20hrs to build it at £50phr :total £7660 for bare engine at the very least.
drivetrain (gearbox and clutch about £6k so agreed) but standard prop and driveshafts wont be good enough so add at least £3000 probably loads more tbh, now up to £16460
suspension : half decent shocks £1000, all the polybushes and whiteline shite approx £500
total so far £18160
turbo : actual turbo £1000 minimum, manifold £1000 minimum, wastegate £300 minimum, exhaust all depends on what you get so for arguments sake lets say £500, turbo lines £100
£20760
cooling: electric waterpump and controller £250, custom rad as you wont be getting anything based on standard dimensions in there £300, decent intercooler £400, pipe run £150
£22060
managment: got to be motec or similar and dizzyless ignition, coilpacks, custom loom etc.etc £3000
£25060
fueling : 3 bosch 044's, fuel cell, swirlpot, plus fuel lines minimum £2000, injectors , fuel rail and fuel reg at least £600
£27660
wheels and tyres at least £1000
£28660
brakes at least £1500
seats at least £600 including mounts
gauges at least £800 as you wouldn't want to rely on old shit and would want to see everything
harnesses £300
full road cage as you'd be off your tits without one £700
not mentioned in your list but would be needed custom inlet £600 minimum.
£33160. not lncluding any mapping, rolling road time, build labour costs other than engine build which tbh will be more like 35hrs, all the silly bits that would be needed, chasis strengthening and things i've forgotten or priced wildly out of any realism...or any vat, duty or shipping as obviously you wouldn't be buying alot of it in the uk..lol
my guess is you'd be nearer £40,000 (doing it all yourself) plus the base car and that doesn't take into account breaking anything , realising it isn't good enough or running nitrous
