who knows how to view bin files (ecu maps)
sypher
sorry the numbers still aren't that clear, try again tomorow and will the car run if the switch is in the other position? I don't know what it goes to, does it go to the CJ1 and CJ2 on the underside of the board?
turbodaily
i havent tried it in the other position yet. il give it a go tommorow, im guessing that the wires go to cj1 and cj2 yeah..
sypher
PLEASE NOTE I have never cam accross an ECU with a small switch with wires attatched inside the unit.. normally the small bridge is moved from one to the other to activate the daughterboard.. I don't want a case of he told me to do this and now my car's &^%(&@
olliecast
I thought that the cj jumper was to enable the ecu to access the pin socket and hence use the daughter board maps.
As you say once this jumper is bridged then the map controls are usually done via daughter board
As above take care, as I don't want to see you fubar the ecu
