weight saving tip
DownunderGTiR
43
0
0
35
so far i got it down to
changing battery(smaller dry cell)
remove aircon
spare tyre
ICE(need only 4speaker and a head unit)
i would not like to go for carbon/fiber glass because it's too expensive for my case of power/cost
in the future i would like to get a new set of lighter wheel also.
would there be anything eles that could help me shave of some weight?
Hai
gunmetalgtir
1,672
0
0
Paisley
What do you think the weight of an R would be if it was stripped out of it's full interior minus the two front seats and the dashboard?
2,894
0
0
43
Deepest, darkest Milk and Beans.
Replacing the OE spring and damper set up, with coilovers almost halves the component weight. Plus, this will be unsprung weight so, even more performance gains are seen !
Front seats are also very heavy (and give cr@p support) !
All surplus rubbish under the bonnet you don't need, is free weight saving although, probably farily minor.
Hai
biggest weight loss will be your gutt if you have one:lol:
keep off the fosters and you could lose maybe a rear diff's weight! (no offence meant):p
jpward
You could also go to the extremes of using a hole saw to cut holes in the A and B and C pillars
Also replacing any non high tension bolts/nuts with Alloy ones like the valve cover, door catches, things like that its big on bikes so places like "pro bolt" can also offer Titan one's if that floats your boat for high tensile applications
9,054
41
48
N Yorks
community.webshots.com
Have you weighed yours at that?
If it's only the full interior with the 2 seats and dash still in, I'd say up around the 1160kg or more area. I think that's about what Kirko's came to with similar mods. Mine has been down to about 1130, but it had other stuff like c/f bonnet, lightweight wheels/tyres/aircon removed, lightweight flywheel etc etc.
3,754
0
0
thats not really the best idea :shock:
you can chop the whole inner door skin out without suffering to many detrimental affects and theres some that will come out of the inner rear quarter panel but i wouldn't go cutting holes in any of the pillars.
5,941
164
63
Wondering how I get 8.89mpg?
Yeah, I had mine weighed on HGV scales. The weight was with very little fuel, no air-con, no interior, one seat (drivers) and some dash.
I'll double check when I go up to work on it this weekend, as I have the exact weight written down in the glove box.
jpward
Why not theres a lot of guys with track cars here and rally cars too that do it cutting round holes does not significantly weaken the structure as the metal grain on the outer edge of the cut is uniformed and this stops tears or kinks from happening
This is all i could find for now
Slightly different angle on things!
9,054
41
48
N Yorks
You'll note they haven't touched the pillars in that car.
I guess if you had a full GrpA style cage it wouldn't affect it too much, but on a road car you'd be risking death if you were in a bad crash.
Boooooost
220
0
16
New Zealand now :)
Do you honestly think cutting holes in some of the main structural parts off the car is a good idea?
I'd say that you would end up weakening the pillars and may cause more body flex. It would be interesting to see the results after a roll over.
Would you do this to your car?
The pictures of the doors is all well and good but its not the pillars is it? From what little I can see of that car the pillars look relatively hole free.
