antgtir said:
Paul,
Ive replaced the following: -
Spark Plugs.
Leads.
Dizzy.
Rotor arm.
Fuel filter.
Fuel pump.
DET Sensor (this was done as 34 code was logged, now fixed and no 34 log).
Ive carried out the following: -
Swapped lambda sensor for known working one.
Re earthed TPS.
Re earthed MAF.
Checked for vacuum leaks (basic soapy water trick).
Things i would like to carry out as a matter of course: -
Pressurised vacuum test.
Adjust existing TPS, if existing TPS does not work with correct voltage test using spare working TPS.
Test using spare (standard) MAF.
Check speed sensor (this was said to not be working when the datascan info was interagated) replace if necessary.
During the change over of the Lambda sensor i noticed that the probe end of the sensor was a whitish colour i.e. indicating a lean mixture. I could just be a little paranoid and this colour is perfectly normal or the engine is either recieving additional air past the recorded MAF volume or the engine is not being fed enough fuel. I will probably take a picture of the probe end when i remove the sensor again.
I love my GTiR:lol:
Cheers,
Ant.
Ant,
So you haven't checked the base fuel pressure ?
Also, I wouldn't worry about a "whitish" lambda probe. I'd expect it to be just biscuit colour for a good mixture and if it was running lean, it should be pretty obvious.
Have you thought about buying/borrowing a wideband lambda controller and sensor ?
If you were going to buy one, the Innovative Motorsport LC1 is a very reasonably priced package and will just require a laptop to view a graphical representation.
The AEM kit is also very well priced and, comes with a gauge so, you can permanently fit it in.
Personally, I'd be tempted to take it to a reputable dyno operator and do a couple of diagnostic runs for £50-£70 ?!
I also noticed you've not looked at the coil ?! Maybe it's starting to breakdown ?!
It's a shame I'm not closer to you as, I'd be more than happy to help you sort this annoyance out. I know what it's like to have this sort of issue so, I can understand what you're going through.
If you want me to look at any of your datascan logs, even if it's just to compare them to mine, let me know.
Keep up the search matey.
Paul
