Lionel,Lionel said:You can get the D2 and the tein serviced in the uk as well.
Where abouts can you get the D2's serviced in the UK ?
Paul
you would think that mate as there made in the same factory :roll: :der:RishiGTiR said:If you can get the D2's serviced here then the same place will be able to sort the K-Sports.
Rishi
Jumping in too quick! im gonna go for some teins cos i need them pronto, killer deal though, im getting the arb's when YOU ALL PAY UP!!!:whip2:sadsy said:i will have a set when you get things sorted![]()
Fazz said:Rob - did you get your replacement springs and is there much difference?
Kev, I can confirm that the 5.3 front and 4 rears work very well on the road. That's not just pool table smooth roads either but, pot holed roads and roads with speed bumps.KevD said:Alan got the test set and then sold the car, his testing wasnt conclusive, I can supply with 5.3/4Kg spring rate but am looking as dampers with longer travel as I still think the springs are too soft for the short throw dampers as they are designed to run with 7/5 springs.
CrazyCrazy said:How much for the springs???
