N
Ninj-r
Not sure if this is in the right place :?
How do you do it? There is no 'how to' as far as I am aware.
Is it straightforward or a mofo :shock: to do.
Cheers in advance.
That's the dual pressure switch. (mentioned above)Ninj-r said:Cheers Fast Guy, I will give it a go. Daft question possibly but what is the silver cylinder thing on the right with tube things (metal) that come out of it? I assume that it is part of the aircon system and that I can remove it with one of those abandon :shock: much like the rest of it
Yes - My aircon is t :shock: ss and blows out air at the same temperature as the normal cold vent, it saves 23-29kg which helps as I have stripped out much of the car that isn't needed & it is a weekend/toy car so doesn't need mod cons. If it is really hot I'd use on of the other carsMajor_Sarcasm said:Can anyone give me a good reason why you would want to remove the air con?
As far as I can see, there is minimal extra load on the engine when the system isn't being used and the weight saving is negligable.
I am prepared and happy to stand corrected.
As an aside, I used my air conditioning in anger for the first time yesterday and it was bloody heaven. Blasts of freezing cold air from the vents when all around me were sweltering
I Pity all you lot that don't have it.
What did you use to get to the nuts on the bulkhead pipes?!!Fast Guy said:Let's turn this into a How to guide then
This is from memory, so any other input/corrections are welcome.
You'll need the front of the car jacked up to gain access to the aircon compressor and the mounting bracket.
First off you need the aircon system degassing. It's illegal to vent the gas to atmosphere. So don't get caught doing anything else.
I started by undoing the nuts on the 2 pipes at the bulkhead and then undoing the other ends. If your aircon wasn't degassed properly you'll get a hiss when you remove one of the pipes, which will make you jump I had to remove the larger pipe through the bottom of the engine bay as it kept catching on the turbo heat shield going the other way.
:?: A spanner :!:Ninj-r said:What did you use to get to the nuts on the bulkhead pipes?!!
Absolutely nothing I could get my hands on would reach it (which p!ssed me off greatly)
What stuff :?: You can clearly see the top aircon hose. There's nothing in the way :?Ninj-r said::roll: No - I have that stuff in the picture in the way.
