I'm sure this has already been covered, but I can't find a definitive "how to" for it.
I've got me a 80401-62C00 (LH hinge for a N14 Sunny - it matches in FAST) from eBay, and I've had a look at the door.
I can see that the easiest way to get at the bolts is to take the wing off, but I noticed that other people have said that you don't need to.
Can you access them through the wheel arch; that seems pretty tight (I'm not sure I could get a socket on that, and I don't think I can get enough torque on a 12mm ring spanner)?
I also saw a thread where Ant (I think) had said that you need some of the soft compound to go between the new hinge and the chassis; where do I get that?
Looking at my car, someone has already replaced the top hinge but not the bottom one. I figure I can put the new hinge on the top and swap the newer one to the bottom (and throw the old one out). - Any foreseeable problem with that; they seem to be the same part?
