liam, once the brackets out the way then getting the starter out is a doddle.
access it by putting your hands in from the top of gearbox at the backend under plenum, undo the 2 retaining bolts and pull it back then lift it forward and out.
once you have pulled it forward you will then be able to get to the 13mm nut which holds the main live cable on, which you can then release, then just pull the spade connector off which goes to the solenoid also, then just pull it out and fit the other one, and leave the Y bracket off.
trouble is like me you have big mitts lol so be prepared for a bit of pain and bloodshed:lol: :lol:
