noriek2003 said:whats your name ? bruce fooking lee, i'd personally love to see a you tube vid of you punching effortlessly through a 3mm thick sheet of alloy :lol:
i take it you've taken into account the differences in the end cases which doesn't appear to be year dependent ?
red reading said:the final drive is helical cut which causes problems,and correct me if i am wrong no one makes straight cut final drives yet
nismoboy said:ppg make a straight cut final drive,
Does the end case get Hot.. Say over 60°c As i know a product that will make a identical Cast.. And have the impact resistance and tensile strength of nylon..And cheap as chips to buy and apply ...pulsarboby said:not quite right there robbie!
im still gonna do this when i get a chance to finish what i started.
i need to make another mould (which is the hard bit);-) the first one i made wasnt quite right.
basically it will be an outer glove which fits over the end case which is a perfect fit but its not gonna be made with just matting and resin.
i tested one of these i have on a press and the endcase will withstand an extra 30-40% pressure (laterally) and end to end before it cracks!
eg imagine holding up an alloy sheet which is say 1/8'' thick, you could punch a hole clear through it with your fist quite effortlessly.
now back that sheet up with a 1/2'' sheet of fibreglass and a secret ingredient8) then try punch a hole through it and il guarantee your knuckles will break before the allie sheet does;-)
i will have the kits made for these this year (before xmas) they will all be a perfect fit and will be bolted to the endcase also for extra rigidity and come with full fitting instructions.
and the good thing is that i know they will work.
