slipping clutch after recon gearbox FITTED
AS above,had a second hand recon&shotpeened box fitted about 9 weeks ago. i had to garage my R cos i couldnt afford to insurance it aswell as buy another box + fitting, so some weeks have gone by and i eventually got it insured last thursday
BUT my clutch is slipping, i had a brand new exedy organic fitted back in jan by the same mechanic, im, led to believe that it cant possibly be worn already, its done 10 launches and covered less than 5000km's , iv been on exedy webpage and this is exactly the symptoms im having
Engine revving when power applied during acceleration / will not transmit power. Evidence of oil contamination on cover assembly.
Symptom :
Clutch cover pressure plate assembly contaminated with oil.
Cause :
- Repair oil leaks.
- If re-using a cover that has been contaminated with oil degrease the cover assembly and lightly lubricate diaphragm pivot rings before reinstalling with light base oil.
now my question is were do i stand with regards to having the problem fixed under warranty with garage.That is of course that i have diagnosed problem correctly??????
cheers johnsy
