AJ4 said:
i certainly did remove it, but i also bothered my **** to find out exactly why it was there in the first place, what it did and how..... and why i dont bloody want it on there :lol:
your all focusing to much on the words unburned fuel in the sense of seeing it as petrol, this is not the case, it is the molecular structure of what makes the petrol, i.e hydrocarbons, whats a hydrocarbon ? it is any chemical compound that is made up of hydrogen and carbon. It is this unburnt fuel (hydrocarbons) that can cause problems with degridation of oil quality and emissions, it is the build up of unvented excessive crank case pressure that can blow oil seals.
unvented means breathers blocked off.
If you re-read my original post about the pcv you would see that the standard ecu is mapped to take into account the recirculation of these gases into the inlet, where it is burnt during the combustion process, that post wasn't pulled out of my anus but based on a technical paper detailing the purpose of the pcv,
i cant see where this problem with this unburnt fuel thing is, what the fook do you think the catalytic convertor was for ?
Most modern cars employ a three-Way cat. It reduces nitrous oxides into nitrogen and oxygen and it oxidizes unburned harmful hydrocarbons and carbon monoxide into water and carbon dioxide.
carbon monoxide is created during the combustion process which the majority of passes out of the exhaust with its good old mate mr nasty hydrocarbons. Surely you can see the relationship here between exhaust gas i.e waste products from the combustion process, what leaves the exhaust and what gets passed the rings as blow by.....?
yep, thats right, what comes out of the exhaust in large quantities also gets past the rings as blow by in smaller quantities, now if exhaust gas contains hydrocarbons so will the blow by
i could waffle on some more about oily inlets and why i wont be having re-circed emissions crap on my car but i wont :-D
all i'll say is i will be running a modified breather system that will quite nicely deal with any blow by and the problems they can cause
