L
lead
Hi everybody, I`m new here. Live in Norway, bought a white R this fall, imported it from Belgium. Here is a picture, mines the white one with silver rims on the gravel. http://forum.200sx-ogn.org/viewtopic.php?t=8587&start=20
The car is completly standard, and I am looking to upgrade the handling first. My budget for the handling part is about 2500£. I was thinking about getting the works kit, and I see that whiteline also has some option parts. Does anybody know which one of these option parts I should get? All of them?
Here is the option parts list from whiteline.
Front alloy adj. strut tower brace KSB530
Front heavy duty swaybar 27mm BNF23
Front of front control arm bush kit (4b/2t) W0568
Front bump steer correction kit (Powerstation UK) KCA374
Rear alloy adj. strut tower brace KSB535
Rear control arm bush kit (16b/8t) W0567
Rear trailing arm bush kit (8b/4t) W0566
Rear subframe lock kit KCA349
Rear 20mm fixed swaybar BNR23
Performance bump stops x 2 kits W0922
This is the works kit:
Springs Front low - Control 325 83109A
Rear low - Control 335 83110
Shocks (6) Front externally adj. insert conversion (x2) 1302412
Rear adj. insert conversion (x2) 1302902
Swaybars Rear 20mm adjustable blade BNR23Z
Bushes Front swaybar link bush kit W0007
Front swaybar D bush kit-28mm SPF1135-28K
Align Front camber bolt kit KCA412
Front anti-lift/castor kit KCA346
Rear camber bolt kit KCA412
Also, any other suggestions on how to make my R handle like it`s on rails, is greatly apriciated.
