3
323GT-R
The standard turbo can make way more than 1.2 bar... BUT! Boost doesn't neccesarily make power, the important factor is the MASS of air. As a general rule of thumb, more boost will produce more torque, but it won't always produce more power. To make power, you need the mass of air to be high at high engine speeds, and this is where the restrictions come into play.
You could take a bog stock GTiR, stock exhaust, stock fiter, stock everything, wind the boost up to say 1.4 bar, and probably end up with less power than if you for example fitted a decent exhaust, filter, front mount, cams etc and only ran 1 bar boost still on the stock turbo On my own car, I've gained a fair bit of power without increasing the boost, all through paying attention to all the small details of maximising the amount of air that can flow in and out of the engine.
The stroker kit does only increase the capacity by 10%, but due to the altered rod / stroke and bore / stroke ratios, the whole characteristics of the engine are different. The standard turbo is now mis-matched with the engine, which is crying out for a big turbo... :lol: It's hard to say what exactly is the situation with Ed's stroker on the stock turbo, but my guess is because the stroker produces more low down torque, it's feels less powerful than it really is at the top end. It seems strange that injector duty is higher in the mid rpm than the top end though :?
