Braveheart
Having read many threads on here pertaining to increasing power, I've been reluctant to do so given the amount of money and time required. I am considering either selling this car and buying one that has been upgraded or just bite the bullet and start upgrading this car. I want a car for track and hillclimb use with power output about 300bhp / 270ft/lb.
Each event probable cost between £350 -£400 (fees, fuel, tyres, brakes, lubs, servicable parts and unforeseen issues) so even after the prep cost's it's not a cheap hobby. It is in my opinion though, the best fun you can have "with your clothes on"
I have a prep budget of £6000 and would like your opinions.
The Car as it stands:
It was imported in 1999 and has had 2 previous owners.
I have all the old MOT's and beleive the mileage it correct.
Current MOT (Nissan dealer) & TAX until Feb 2008
The bodywork and underside are in good condition.
Engine & transmission feel strong and quiet.
Full Service Feb 2007 (all lubes changed) new plugs, dizzy cap, rotar arm and leads and DET sensor.
Bought the car in November 2006 for £3800 and I've spent over £1500 to date. Do you think I could get 4k for it?
L reg 1994
41,000 mls
Standard:
Engine
Gearbox
Clutch
ECU
Upgraded:
GAB adj suspension front & rear (on when imported)
Front Strut brace (spats) (on when imported)
15" rims + Toyo R888's (April 2007)
Walbro 255 fuel pump (Feb 2007)
Forge BOV (Feb 2007)
Delimitted + new dials (Feb 2007)
Manual Boost Controller (Dawes device) April 2007 set at 14psi
Parts not yet fitted:
Please just tell me to sell this car and get another hobby:roll:
L reg 1994
41,000 mls
Standard:
Engine
Gearbox
Clutch
ECU
Upgraded:
Wilwood 280mm Brake kit
FMIC
Apexi SAFC
If I choose to upgrade then I think I need to do the following but there are a few grey areas that I'm unsure of and maybe some that I have listed that are not nesessary and probably others that I have overlooked. Oh my... it's looking pricey. Think I may have under budgeted!
Car transporter
Spare wheels and tyres
New Suspention (fully adjustable)
Other Suspention work
Full roll cage
Bucket seats + Harnesses
Piggy-back ECU
Electronic Boost Controller
New gauges & sensors
Uprated Clutch
Top mount oil cooler
Uprated radiator
Uprated Induction
Uprated gearbox?
Engine internals? larger injectors?
It may be cheaper in the long run to upgrade engine now before it gives up, however if I have the cooling and fueling correct it should hold together... hmm.FMIC
Apexi SAFC
Car transporter
Full roll cage
Piggy-back ECU
Uprated Clutch
Uprated radiator
Uprated Induction
Uprated gearbox?
