My two cents, as I've just had all this apart - sorry about the long post:
These pipes are purely to scavenge any blow-by or oil vapour which has made its way up into the area above the valves. Inside the rocker cover there is a closed off area which eventually goes to both of the breather connections, and is open to the area inside at certain points. I haven't cut this open personally (yet :twisted: ) but as Frank said I'd expect some sort of baffling in there to act as a seperator to avoid liquid oil going out the breathers.
There has to be a one-way valve between the throttle bodies and the breather, or when you get on boost your engine will start blowing seals left, right and centre - apart from the combustion chambers no part of the engine internals should ever be under pressure. This means on vacuum at part throttle, the system will draw the vapour from inside the rocker cover, through the seperator stuff and into the throttle bodies - if your seperator is in good nick or your vapour is not too oily, there will be no visible residue. Mine happened to have a bit of oil in it, doesn't bother me.
If you remove this pipework (I did, it was in the way of some bolts) you still have the right-hand breather connection to the inlet pipe which will do exactly the same job - scavenge vapour from the rocker cover. This is also the vacuum connection to the oil seperator which only deals with the blow-by gases in the crankcase, the liquid oil should be seperated out and return to the crankcase, any vapour returns to the inlet tract and is burnt in the engine (and covers your turbo and intercooler
 ). If you remove the inlet pipe connection and run it to a catch tank thats open to atmosphere the vacuum won't be there to draw out any unwanted gases - you may also get an oily smell as the system is no longer sealed, but no oil will get back to your intake system.
Another way might be to run the vacuum connection to the intake pipe through another (more efficient :?: )seperator to get rid of any residual oil mist in the drawn out gases. This is what I'm going to look at doing, as I do have oily gunge and I don't like having the system open - just my preference.
AndrewD - there are many members on here who do have the ability to look at an engine and decide whether changes to a system that Nissan put on are worth doing. People don't always just look at a mod that a tuner does and go "Hey, that looks cool! Off come the pipes". I don't have any problem talking over another point of view, but if you're going to call me an idiot I'll invite you, as friendly as possible, to fook off
Anyone got a spare rocker cover they fancy sacrificing to find out exactly whats under that closed off section :?:
Thats it, any different ideas how it's supposed to work :?:  Shows over, thank you for coming
