Standard service parts?
B
bean
I've had my R nearly 3 months now, covered 5k miles and plan on giving it a service.
I am mechanically capable of doing most jobs, used to service my 200sx myself and had the gearbox turbo off myself.
Can someome give me a guide to the service parts I should replace please? This will be it's first proper service since being in the UK as I don't consider the dealer I bought it from did a proper job. [:(!]
My list so far:
Oil & Oil Filter
Distributor cap, I guess I need a rotor arm as well?
Fuel Filter
I'm sure I'm forgetting loads of bits but it's Friday afternoon and I've started drinking already. [:D]
I have an aftermarket air filter (I've already replaced the element) and am running Denso spark plugs.
I'll be replacing/uprating [;)] other parts as they wear out.
Custom GTiR ECU Maps coming soon
www.h-dev.co.uk
Add all transmission fluids and cooling system to that list.
Brake fluid and clutch fluid if you can be @rsed [:)]
It's a big black fly swat
GTI-R Kid
Maybe new HT leads[?]
And dont forget the copper washer for the sump plug.[;)]
B
bean
quote:Originally posted by andygtir
i change the oil every 3000 miles max
andy
I thought Nissan recommended every 5000miles?
I haven't done any track days or 1/4 miles, just normal work driving so 5k intervals should be ok.
www.h-dev.co.uk
GTI-R Kid
Nissan do recommend every 5k, but if you really love your car then you'll change that interval to 4k or even every 3k just to keep it in top shape.[;)]
B
bean
Which transmission fluids should I replace besides the Gearbox? [?]
www.h-dev.co.uk
E
Edd
I change oil every 1500k miles [^]
Although done about 7 oil changed so far this year [V]
1600 miles and somethings blown!
B
bean
[:0] Every 1500000 miles? [:0]
You sure don't mean every 1.5k miles or 1500 miles? [;)]
www.h-dev.co.uk
gearbox, transfer-box and rear diff.
Have a good look at the cv and drive shaft gaiters whilst your at it to see what condition they're in.
Ex-gtir spotted that one of mine is on the way out at the weekend, so i know i'll need to sort that now.
Could also give the oil seperator a good clean out.
Mr Overboooost
heres some usefull nissan part numbers for you:
drive shaft gater p/s front(hub side) 3924163y25 £22.00
fuel filter 1640053j10 £10.20
oil filter 1520870j00 £5.20
drain washer 1102601m02 £1.10
rotor head 2215754c01 £6.40
cap distributor 2216253j00 £15.40
ht leads 2245054c27 £42.00
hope this helps[:D]
cheers
gary[:)]
B
bean
hope this helps[:D]
cheers
gary[:)]
Thanks, they'll definitely come in handy.
I guess the only place to get parts from is a Nissan garage? The money grabbing bastards charged me £3 for a bloody packet of plastic trim screws last time! [V]
www.h-dev.co.uk
