Removing ABS Wheel Sensor
geetee
Hi
Just had my efforts to change a front wheel bearing foiled today by the s*dding ABS sensor. How are these meant to come out of the hub? - I took out the bolt in the bracket but it's stuck solid.
Alternatively where is the electrical connector? In the wing or in the engine bay?
Oh - and lastly.... should I use a hub puller to pull the hub out of the hub carrier whilst on the car or just take the whole hub and carrier off and knock the hub out from the back?
Graham
Both front ABS sensors unplug in the engine bay mate, Just push through the rubber gromit and take the whole hub off as one unit, I just get my mate at the local garage to do mine for me, I think it was £77 last time including parts.
The plugs are located on each strut tower so you don't need to look far, Drivers side is down below the power steering reservoir somewhere.
rob
