Rear Brake Binding
Symptoms are rear right brake binding constantly and handbrake tighter than normal.this is progressive as new set of pads 2mths ago fine until a few days ago, although car still felt as though it were dragging now seems really bad any help much appreciated ps when changed brakes last cleaned all slideways etc prior to reassembly
Si
AZ STE
This is usually down to the handbrake lever on your brake caliper siezing remove the cable from the arm on your rear caliper try and get some release oil down the shaft and tap/move the arm backward and forewards to release it. It may sieze again in the future to stop this put a secondary spring on the arm to pull it back this usually helps :wink:
