That bolt is just a stop, the adjustment is done by slackening the lock nuts on the push rod between the pedal and the master cylinder and twisting it round either way to get the desired adjustment. Its a bit fiddley but not impossible. Have you had a good look at the pedal box for any signs of cracks? Do you know if you have a support bracket fitted?olliecast said:yeah i put redline it in and it definately inproved the slickness for a while then it just went back to normal (may be me just getting used to it).
do you mean gearbox or clutch oil?
clutch adjustment bolt is all the way out.
i`ve never bled the clutch but just noticed that the gater on the underside or the box is missing. there`s also a slight bit of oil weaping from the underside of the box. doesn`t see mto be of a volum that`d cause issue though
It would be a good idea to change the fluid if you have never done it.
Do you mean the selector shaft gator? These are often split, and its common to weep a bit from the seal, nothing to worry about if its not pissing out.
