It's not got any free play, it feels like it did before, just alot heavier due to the twin plateMarkTurbo said:Is there any freeplay at the top of the pedal (ie over the 1st inch or so when you initially push it down)???
If theres too much you'd need to adjust the rod from the master cylinder to the pedal as you might not be getting enough travel to disengage the clutch fully ;-)
The release bearing was fitted, it wasn't me that fitted it though. Because the gearbox is so heavy I couldn't lift it by myself (I'm quite short:lolgunmetalgtir said:It probably is the release bearing if you forgot to fit it! :doh: :lol:
Why was he fitting it while you were lining up the box with the engine :? You should have the release bearing assembled onto the clutch release fork well before you think about putting the box anywhere near the engine!Adam L said:so while I lined it up to the engine a mate fitted the release bearing on the input shaft, wether he's done it properly is my main concern now.
Feck I must had read that wrong! :doh: :lol:Adam L said:The release bearing was fitted, it wasn't me that fitted it though. Because the gearbox is so heavy I couldn't lift it by myself (I'm quite short:lol, so while I lined it up to the engine a mate fitted the release bearing on the input shaft, wether he's done it properly is my main concern now.
Feck, I must had read that wrong! :doh: :lol:Adam L said:The release bearing was fitted, it wasn't me that fitted it though. Because the gearbox is so heavy I couldn't lift it by myself (I'm quite short:lol, so while I lined it up to the engine a mate fitted the release bearing on the input shaft, wether he's done it properly is my main concern now.
Apart from this bit, he's in Norway! :lol:Odin said:And they are in this country if you need spares or have a problem that needs sorting out
