Power graphs only!! read before posting
Fusion Ed
Nice one nick! That car was a beauty to map. Absolutely perfect on the dyno. Loads more to come if you get bored and get a better box too ;)
Fire & skill
Vintage member
at scottish RR day held at star performance - 12/12/04
336bhp
292lb ft torque.
using RB box (dakar)
mods: hks evc3 (set to 1.2 bar for run)
timing set for jap fuel - octane booster added +2 ron. 100 ron
k&n ind kit
standard t28 turbo
standard injectors
standard internals
remap by buddyclub Japan (well it says this on the ECU!)
helix clutch
and thats about it, still had the cat fitted.
the car is as it came from japan, only the helix clutch has been fitted by myself since
I have a chance to buy this car back :thumbsup:
I would love it back, this was my first R
potoss
SR22DET
GT3071R
Tomei procam 282
Darton sleeves
CP piston 90mm
Tomei valve springs
Eagle rods
Nistune
No avcr not working here
OS Giken R2CD
Braveheart
258.2 whp@1.1bar / 229 FtLb Torgue. Approx = 350 bhp @ flywheel
Standard Engine Internals
GT2871R 3" inlet 0.86ar
ARC top mount intercooler
Greddy profec b boost controller
Z32 air flow meter
Blitz 660cc standard injectors
Apexi Power air filter / cold air box /
AM performance turbo elbow and 3" downpipe / mid section
Mongoose exhaust system
Walbro 255lph fuel pump
vpulsar
Re-bored standard block.
lightened and balanced tuftrided crank.
ARP main studs and rod bolts.
Nismo head studs.
Par forged rods.
HKS 87mm coated pistons.
HKS 2 mm head gasket,
Kent cams & adjustable sprockets.
GT3076 turbo running 1.9 bar
external 44mm wastegate.
1000 cc injectors
Motec M48 pro ecu.
charge cooler.
and loads of other random shite lol.
John
daddyone
Max torque 821Nm @ 5296
Max Power 226.3 kW @ 6867
Mods
Custom FMIC
walbro fuel pump
sard 700cc injectors
Cams:
Cam Lift Duration Duration Valve Valve Cam Lift Phase
Adv @050 Clr Lift tdc <)
Intake 274 276 218 0.006 0.4096 n/a 108
Exhaust 274 270 218 0.008 0.4076 n/a
arias 86.5mm pistons
crap 6 puck ceramic clutch
balanced bottom end
Mallory hyfire ignition and coil
$3 spark plugs
link plugin ems
2 3/4 nismo exhaust
1.2bar boost
i am quite happy, there is heap left in the motor and turbo but the link can only handle 1.55bar. I need to source a ebc to hold 1.3 bar which should see me past the 240 mark.
matt
[/img]
821NM? Is that a misprint?
