How many more times can someone say the same thing. The injectors have nothing to do with it. Just because they're rated as bigger, higher flow injectors, doesn't mean they inject/flow more fuel. It just means they can inject/flow more fuel. Forget the injector size, just look at it this way, in the simplest terms. Your current injectors can flow more fuel than the stock injectors, before they max out. That's it, nothing more, nothing less.turbodaily said:how do you think it would run if it put the standard injectors back in, with it being mapped on the 550's? and are the evo 3 510 injecters a direct fit? as i have a set of them too.
funny that mate, i had a word with paul at engine advantages and he too suggested it might be a good idea to put the standards back in, which i did this morning and it goes much better, no hesitants between gearchange, and no flat spot at high revs. think il give it a quick run up on the dyno again to check and adjust mapping if it needs it.youngsyp said:How many more times can someone say the same thing. The injectors have nothing to do with it. Just because they're rated as bigger, higher flow injectors, doesn't mean they inject/flow more fuel. It just means they can inject/flow more fuel. Forget the injector size, just look at it this way, in the simplest terms. Your current injectors can flow more fuel than the stock injectors, before they max out. That's it, nothing more, nothing less.
If the car has been mapped with them in, as long as the map is good, the ecu won't be over fuelling the engine.
Putting the old injectors in will just screw up your map, as the ecu's injector duty cycles will be different due to the differences in flow rates of the two sets of injectors.
If the car is still not behaving correctly, take it back to the mapper and explain your issues !
Well, that is odd, and goes against everything I understand about the subject, admittedly that is pretty little though !turbodaily said:funny that mate, i had a word with paul at engine advantages and he too suggested it might be a good idea to put the standards back in, which i did this morning and it goes much better, no hesitants between gearchange, and no flat spot at high revs. think il give it a quick run up on the dyno again to check and adjust mapping if it needs it.
