i have the same spark plug but mine are 9 heat range. i had a similer problem with some lower number spark plugs ... most ppl yse the 7-8 heat range.turbodaily said:it basicly does it higher up in the revs,in any gear,but i notice it more in 3rd and 1st gear. it just splutters and bogs down for a mini second and then picks up and goes.
does it quite often when booting it,when changing into 3rd gear and then putting your foot down again it splutters then picks up again. but if you change gear slowly when booting it, it tends not to do it. but it does it quite alot in 1st gear if you floor it, as soon as it comes on boost.
its got ngk iridiums in it,which is the next question what should they be gapped to, think its 6 is it not?
