i think so,it is on the corner of the block on the front by the thermostat housing, try doing it up with an allen key when its in as you wont have much room! its there to seal an oil galley btw.
Cant see you being able to get much torque to clamp / seal an oil gallery? the bolt is only M6 x about 40 i think, how does it seal? does it pull the corner of the head down or something?i think so,it is on the corner of the block on the front by the thermostat housing, try doing it up with an allen key when its in as you wont have much room! its there to seal an oil galley btw.
Do you think i will be able to re tapp this bolt hole m8?if you dont put it in you will have an oil weep/leak on that corner,it works as you say by pulling the head down.
Hiya Guys,
couple of questions on the rebuild of my R,
Now my head is off and mindful that there is only a problem with number 4 cylinder, but no apparant piston crown damage, can I take the head to a skim / engineering company and have the valve seals, guides and valve seats checked? yes
Although i have tied the timing chain up and set the timing, I need to rotate the crank to check the bore in number 4, can this be done with the chain in situ on the crank pully. yes if you are carefull
sorry about all the questions again.
cheers,
Lee
because the one thats coated in oil seems like the 0ring seal to rockercover has failed so that plugwell will fill with oil.
thats a 50p fix lol
Thanks,Bob,im back now lee
if youve only got 40psi compression on no4 and the ex port is wet with oil then remove the alluminium and metal part of sump then unbolt the conrod on that particular piston and push the piston out to inspect it.
i guarantee you that it has a cracked ringland or broken/seized rings ; ) may also have scored the cylinder so you need to check that very carefully.
assuming the cylinder is ok (ideally check it with a bore dial gauge for ovality) you just need to hone that particular cylinder and youll get away with fitting a s/h piston.
if the cylinder is more than 8thou out of true or has bad scoring then youve got real probs and will either need a replacement engine or a rebuild/rebore on the one you have.
dont just put it back together without checking that bottom end or youll be back to square one
Hi Guys,im back now lee
