No brake lights
Scrim_R
Hi all,
My brake lights are not working. I have replaced all of the bulbs, checked the fuse and made sure they are connected properly but still no joy. I asked my friend who I bought the car off and he said that it could be the brake switch above the brake pedal. Has anyone else had the same problem? On my friends R when he presses the brake pedal you can hear the brake switch make a click, but on mine it doesn't.
Hope you all had a great xmas :-D!!
Cheers,
Matt.
Scrim_R
I haven't physically removed it, but when I press the brake pedal it releases the pin as it should. Maybe something inside the switch has gone? Would i be able to test this in any way with a multimeter or anything?
Cheers,
Matt.
Garef
You should be able to check the voltage coming into the switch and the voltage leaving. That would be your best bet.
