Fazz
Bit of clever deleting there ya sneaky one!Odin said:What post you on about fella ? :shock: :lol: :lol: :lol: :lol: :lol: :lol: .
You're the one on drugs matey ;-)
Some of us are too fast.... (shame about our cars :doh: :lol:
I think its a shame to leave the Pulsar ways but I also know what it is like to try and keep one of these bitches on the road Fazz don’t make a final decision until the heads off and you know for certain if it will need machining work then if it is more costly to repair in the long term just go ahead and break her thou if you could leave this for like 6 months whilst making absolutely sure you wish to break I should be in a better position to help with your parts disposalFazz said:That second post a bit crazy there Robbie !
Have you been drinking???
@boby - I take your point, I've crunched the numbers and I'm not repairing it.
It'd be another 1.5-2k by time on road (rad, stat, water pump, recovery/transport, head, gasket, skimmed etc) and I'm not doing it. Even if I repaired it it would be to sell on and they are hard to sell over here at moment. Hell they're worth fook all over there too!
The block could even have problems but won't know till stripped.
I've done a rough list of what I know will sell and what may be hard, there's also a few round here that are in process of modding so may take a few bits at once.
Haven't even included body or panels as they'll just be pot luck.
Decision is made.
Fazz said:Thanks for trying Bob but here's how it stands.
Recovery - 100 miles, minimum 150
Head Gasket - 200
Head will need to be leak tested and if fine prob still skimmed - 200 at least
Rad - no point gettin standard - 300 min.
thermostat - 50
water pump - 150 at least
labour - prob 300 ish.
Thats at least 1.3k, (Euros), labour probably more, same with recovery, plus oils, tax for another 3 months of 350, easily gonna be 2k by time back on road.
And thats best case. if head is worse, or block is screwed then more.
and I didn't even mention the fact it would need another remap....![]()
Your cam timing changes slightly as the tought side of the chain would lose a few mill do you have adjustable sprokets?Fazz said:Well thanks for the kind words and views/solutions.
I'll have another think.
Also I'm on a 1.8mm gasket so only way I wouldn't need a remap is if i get same on. I'd need a remap if head skimmed or if I changed size of gasket wouldn't I?
Not convinced but you've forced me to have a re-check and maybe confirm prices for definite.
I think chances are at least that the head would be warped. Tends to be pricey round this neck of the woods...
I hadn't realised you could get a gasket that thick. Maybe its the problem as its not sealed well?Fazz said:Also I'm on a 1.8mm gasket so only way I wouldn't need a remap is if i get same on. I'd need a remap if head skimmed or if I changed size of gasket wouldn't I?
And you can ignore that cost unless you are going to start breaking it at the side of the road. Surely you have to recover the car no matter what ;-) :lol:Fazz said:Recovery - 100 miles, minimum 150
pulsarboby said:hes got no excuse now but to fix what hes damaged:lol: :lol: :lol:
if he breaks it and dissapears from the forum then what irish laddies are left for us to poke fun at!!!
well only have jp and he dont really bite that much:sad:
seems not. Esp when he's a bogtrotter :roll: ;-) :lol:Jees can't a man curl up in a corner and cry to himself??
