midnightpurple
and i think I am there aready ;-) not the first time I have managed to do that to myself. Hope the thread doesnt feel jacked..... Should be covered to death unless there is a simple answer LOL
:lol::lol: .........yer I think there is too much of an answer here lol.
Shall i sum it all up?
- Rewiring the fuel pump is better because..... it just is!![]()
:lol::lol::lol::lol::lol:I'm not a big fan of the mass debate of niff naff and crap from peeps that know something about nothing
I don't specifically mean earth. The drop is more likely to be on the live side, as that run is longer on the pulsar. Under boost I have had fuel pumps on pulsar drop to 8volts. This causes a pressure drop. this can be hidden if the injectors are large as you just open the duty further but this means the map is not linear - and is how I can tell if there is a problem with the fuel pressure. I.e. x load = x fuel, 2x load = 3x fuel = problem. x load = x fuel, 2x load = 2x fuel = expected, all is ok.I've said "how to" but for the record could you explain technically why it works and makes so much difference over just re earthing the pump.......please
Steve
See, now that I understand!!! As for the rest of it!! :doh:x load = x fuel, 2x load = 3x fuel = problem. x load = x fuel, 2x load = 2x fuel = expected, all is ok.
HTH.
Ed
depends what wire you have? the fuse is there to protect the wire and needs to be rated lower than the cable. Sorry to get technical again :sad:just to double check, the fuse between battery and pump is 30A?
