how do i disable abs
N
N1SMO
how do i disable abs as it keeps on comming in at low speed braking for no reason.
E
Edd
i would havethought pulling the relay out would do it :lol:
located in the relay box on the drivers side engine bay by wing :wink:
N
N1SMO
is the fuse in side the car as i dont know what fuse does what, is all jap writing.
And will i cause any problems disconecting it.
Thanks guys
Ian
fuse box is in the engine bay by the wing.
you`ll get the abs orange light up all the time and no abs activation which could have insurance implications if you have a prang :cry:
N
N1SMO
its better than the abs kicking in at slow speeds, this morning i nearly ran into the back of a car because the abs came on and i could not stop.
abreesa
mine done exactly the same thing.
tried cleaning up sensors got new pads ....didnt work
I just pulled the fuse and the abs bulb from the dash (cos it is the most annoying thing in the corner of your eye)
Fuse is a kind of block shape found (on mine) in the passengers side front wing right of the battery
N
N1SMO
I have pulled the green square fuse thing but still to take the anoying bulb out.
Does anyone have a reason or fix for the abs problem at slow speeds.
