skiddusmarkus
Just turf some old biddy out of their seat if there isn't :lol: .
skiddusmarcus
Sirnixalot
could always do it mission impossible stylee :lol:
Got my MD214 turbo now but when I spoke to Craig from yurbo dynamics he said that all his units directly replace the standard T28 but roller bearing units require the oil drain pipe flange to be changed which he supplied :? :?skiddusmarkus
The MD214 needs slight modification to fit.The oil return has to be welded up and redrilled as the bolt holes are very slightly different(took ine to an engineering firm and they charged about a tenner to do it).I then had to alter the gasket to suit.Also,on the turbine side where it bolts up to the dump pipe/elbow,one of the bolts is in a slightly different place so your elbow needs on of the holes filing out by about 2mm.
Another FUBAR production :lol: .I just enlongated the holes abit lol
Just opened up the box that the turbo was in so I could have a good look because when I explained this to my local garage they looked rarther lost and started backing out of doing the job :roll:Just got a call back from the company I bought the turbo off and they said that I should hacksaw off the oil drain flange and weld the new oil drain flange back on in exactley the same place
Sounds simple enough
who did you buy it through - I need to know so i can try avoid customsDavidmo said:I just ordered a HKS GTRS Kit but its still in customsMate u wanna order the S15 kit
The duty for turbochargers is 5% in Oz... and the rule is that it's based on the actual price paid. With legitimate receipts etc, it should be a problem.Allan GTI-R said:who did you buy it through - I need to know so i can try avoid customsDavidmo said:I just ordered a HKS GTRS Kit but its still in customsMate u wanna order the S15 kit
FYI customs have been speaking to the local distributor to see how much anything HKS is worth, so expect to cop the 15% or whatever it is on $3999 - that's the recommended retail price to buy that turbo locally :shock:
use the flange of the return line provided with the GTRS and the elbow of the std return line...just weld them together.GTIR-LOZ said:the only things that wont line up with the gtrs are the actuator mount and the return line to the sump, which is the bit im currently looking at trying to get, would a samco doubly thickness hose be ok from the flange to the sump, iof i cut off the pipe at the exit??
