Doubt it, as said before pistons and rings are not bedded in so will more likely be the oil control ring leaking.....needs time to bed in. If the head was cracked that deep to hit the oil gallery you would have seen it very very easily. The oil leak from the back of the block could be oil filter housing, or timing chain tensioner. Are you sure you have had it running long enough to burn the oil off the piston from the engine being built or that it is not fuel sitting on top of the pistons?
