Rishi
Still waiting on some shims!
Think of it like this...campbellju said:I'm interested in getting my head round the 3" elbow vs boost surge vs turbo response.
The quicker you can get the gas out, then the quicker you can get it in. Thus engine works faster.
Now if your 2.5" turbo elbow is restricting your gas flow then there is only so much that can be expelled from the Turbo at any given rpm.
If you increase the flow capacity of the turbo elbow then the turbo has less back pressure and is able to expell more gas at the same given rpm.
Because the turbo is expelling more gas at the same given rpm level the turbine must be spinning at a greater rate yet at the same engine speed.
Thus you have just increased the spool and response of the turbo.
Now with this the turbo is going to spool up at a greater rate. Using a the tiny internal wastegate to suggenly hold at a set boost isn't going to be easy. It just can't expell enough gas through the wastegate quick enough to stop it over boosting for a moment.
I'm sure there are some others with different ideas but thats my view on it all.
Rishi
