Nick K
Hi all.
One of the three rubber fuel pipes that comes down from the fuel tank underneath the car into the metal pipes that run to the front has exploded about 1" from where it terminates to the metal fuel pipes.
Its the closest rubber one to the passenger side!! From what I can see the furthest rubber pipe from passenger side goes across to the other side of the tank so i'm assuming the other two go up to the sender unit/pump. If this is correct can it be pulled out and a replacement drawn through without dropping the tank!!
The failed pipe looks like a land mine has gone off in it..
Cheers.
Cheers.
