Fault code check procedure
Correct. :)
Check the wiring to the det sensor as it can break or disconnect. The ecu should retard the ignition and cut boost when it detects det. So your car should be feeling sluggish.
Momighty
when connecting the wire or paper clip to the terminals do you leave it connected while the code are being displayed or do you remove it until the codes have finished?
Thanks
steve963
Thanks
connect paper clip for about 3 seconds then remove, the codes will now show
Momighty
thanks, and then once you have done this and you want to clear them or start the car wot do you do because i read if you dont clear it or somthing the the car wont run right?
is it as simple as plug the paper clip back in until it stops flashing and its done?
scottw8943
car will not rev past 2500rpm done fault code check and its the afm curcit will it be the airflow meter thats gone.
The picture from the manual in the first post says..........Check harness and connector, if both OK replace AFM. So check them both and then replace if necessary.
kirko
tried a fault code check on mine, when i short the two pins nothing happens
i have a power fc will this affect it ?
AJ4
yes, because you can't read fault codes with a PFC ;) But then again, why would you want to when you can read and log every single sensor and switch on the car :D
Surprisingly the other day the car felt like rubbish on start up.
By luck i noticed my SAFC monitor showing 100% full throttle.
Obviously my foot is off the throttle.
Did the diagnostic check it mentions AFM instead. Odd...
Swap the TPS and everything was fine again.
Odd....
Braveheart
kev_200uk said:
exactly what it says, i did a code check, it did one long flash and 2 short flashes
12 = AFM circuit.
From page one, post 1:
Here's some of the other codes:
11 Crank Angle Sensor circuit
12 AFM circuit
13 Engine temp sensor circuit
21 Ignition signal circuit
34 Detonation sensor circuit
43 Throttle sensor circuit
55 No malfunction in the above circuits"
kev_200uk
Braveheart said:
12 = AFM circuit.
12 AFM circuit
so what could cause the problem there then??
B
boozyboo
just found some more codes, hope this helps someone.
List of Codes
Pre-OBDII
12 Mass Air Flow Sensor
13 ECT Sensor
14 Vehicle Speed Sensor
16 TCS Signal
21 Ignition Signal Circuit
25 Idle Air Control Valve
22 Fuel Pump Control
31 ECM
32 EGR Function
33 Heated Oxygen Sensor
34 Knock Sensor
35 EGR Temperature Sensor (RH)
41 Intake Air Temperature Sensor
42 Fuel Pump Sensor
43 Throttle Position Sensor
45 Injector Leak
46 Secondary Throttle Sensor
51 Injector Analysis
53 Exhaust Gas Sensor (LH)
54 Signal Circuit From A/T Control Unit To ECM 55 System OK (1990-1995 Q45 only)
65-71 Single Cylinder Or Multiple Cylinder Misfire
72 Three Way catalyst Function
76 Fuel Injection System Function
77 Rear Heated Oxygen Sensor
82 Crankshaft Position Sensor
84 A/T Diagnosis Communication Line
91 Front Heated Oxygen Sensor Heater
103 Park/Neutral Position Switch
105 EGR & Canister Control Solenoid
astarozna
I did work on mine as well(top right and next to it)!
long:long:long:long:long - short:short:short:short:short
mad Al
:? hi my r got engine light on at tick over when i rev it goes out but when drivin it starts missing and wont go over 3.5 its got apexi power fc so wot do i need to get the codes to see wot sensor has gone can anybody help cheers i tried shorting connector but nothing happens so where can i get the equipment to read it cheers anybody
snoon
most garages will have a fault code checker but it will cost you about 25 quid.
If your check engine light works then the fault code check should work. Double check the instructions to make sure your doing it right.
Boozyboo. ALL our (7) codes are as listed in the first post. There are no more codes for our car.
