FAQ - Parts - Weightwatchers II:Post Your Findings
Status
Not open for further replies.
skiddusmarkus
3,288
0
36
Derbyshire
Please post weights of any aftermarket bits you have and the parts they replaced eg intercoolers,rads,brakes,suspension,wheels etc and I'll compile them into a nice list.All weights are approximate as weighed on bathroom scales :lol: .
Standard:
Air con bracket(between block and pump)-4kg
Brake caliper(no pads)4.5kg each
Exhaust manifold heat shield-500g
Intercooler including chromed shield and bracket-8kg
Flywheel-9kg
Radiator-2.5kg(dry)
Radiator fan-2kg each
Toe hook-1.7kg
Aftermarket
Koyo radiator 70mm core-5.5kg(dry)
Z32 MAF-500g
Cusco pillowball topmounts-1.7kg pair
Ap paddle plate(plate only)-2kg
Helix organic plate(plate only)-1.75kg
Ap 6 pot caliper and pads-3.83kg
Ap 4 pot caliper annd pads-3.4kg
Wilwood’s Billet Dynalite-1.13kg
Hispec Billet 4-1.7kg
" monster 4-2.2kg
" mega monster 2.4kg
" racing 4-1.45kg
" racing 6-2.4kg
325mm discs with alloy bell-11kg each
Jun flywheel-5kg
Bliz boost controller-250g
Odyssey race battery-6kg
Forge Pulleys:
Power steering 230g (Original 500g)
Alternator pulley 125g
Water pump pulley 237g
Crank Pulley 800g
Forge front mount :
Intercooler core 5.5kg approx
14 jubilee clips 1kg
Samco hosing 4.5kg approx
Stainless steel pipes around 2.5-3kg
Mongoose exhaust-12kg weightsaving
9,054
41
48
N Yorks
community.webshots.com
Forge Pulleys (weights on kitchen scales)
Power steering 230g (Origional 500g)
Crank Pulley 800g
Forge front mount
14 jubilee clips 1kg :shock:
Stainless steel pipes around 2.5-3kg (guesstimate)
Turini C/F bonnet 8kg approx
Mongoose (turbo back) exhaust system 12kg less than the standard system, mainly down to tail pipe being 1kg (standard back box was 13kg)
ard1ey
Pair of boxed Tomei cams - 5kg on slightly dodgy bathroom scales
Power FC (boxed) - not a lot (in best Paul Daniels voice :D )
stevepudney
GTiROC CHAIRMAN
5,327
23
38
Miles from anywhere
Anybody know the weight of an aftermarket clutch cover, say HKS, Excedy e.t.c
Or the overall weight of the standard Flywheel and after market clutch as above.
Status
