davey red.r
get a civic type r, if you want a mental top end.
								And, I have a pair in good nick that never got sold in the end:-DOdin said:If you want a bit more power and keep the engine with in it's safe operating range then bung a set of HKS 264's in it.
alexpulsar said:personaly im using hks 264s with head ported and polished with 3 angle valve seats . i also got bottom end ligtened balanced knife edged crank lightened flywheel and forged pistons and it revs up loads quicker than any other gtir ive owned .its only running a std tubby as i run engine in at 0.8 bar and it is so much quicker than it was before cams feel exellent from about 4k pulls so savage lol.
Ok cheers so for the normal R rev range the standard springs would be fine if they are in good condition anyway.Odin said:A good engine builder will check the condition of your springs before re using them, Mine where fine for the rev range I plan on using.
For a high reving engine then you would need better springs I'm sure, Their are a few options to choose from.
