jpward said:
Right Diesel weasel you nobber :fu2: you took the wrong context out of what I said in that the simile
oh dear, name calling :lol:
i take it your trying to spell 'similar' ? a stroked engine is so completely different to running lairy cams they couldn't be any more dis-similar.
I was trying to get across was that a stroker changes the character of the engine like how a wild cam would vastly change the way the engine behaves at different load points!
indeed the stroker does change the 'character of the engine, and for a road car it can only change it for the better, what you actually said is :
That sort of spec on an R could make 5-600 id say but the work needed to get the rest of the enigne there is not worth it strokers are a bit like wild cams the wilder they are more high end flow but somewhere else has to suffer I dont think anyone here has much need above the GT3071R or GT3037R to be honest whats the use in all that extra power high end when the best features of the car is point and squirt!
the stroked engine would give you more 'point and squirt' thats the whole point of doing it.
I never mentioned Torque Allen and I do know that is the main benefit of a stroked engine
(Increased VE) and hence why I mentioned the lag or slower response at lower revs.
you still dont get it :doh:, the stroked engine on any given turbo will get it spooling quicker than a smaller capacity engine (unelss you were running nitrous maybe) thats the whole point of doing it. You get more air in, you get more exhaust out at the same revs.
And I got my information from an experienced engine builder who mainly does stroked engines for racing and I spoke about stroking
my engine after a teardown discovered a heavily scored journal so I was in need of a crank anyway!
good luck with your rebuild...and i mean that sincerely
He advised not really for daily turbo road cars as the R is not laggy
and that’s what I like about it most
stick a gt42rs on your car and then say 'the R is not laggy'
i'll repeat it once more, in really simple terms just to see if it finally sinks in, if you increase engine capacity (making its internal volume bigger, either by stroking or over boring) you will be able to get more air in as you now have more room to squeeze it into than on a smaller capacity engine, say a 2 litre. That air goes into the cylinder, is mixed with fuel, compressed (squashed), spark plug sparks, mix goes bangdiddy-bang-bang, piston descends rapidly, exhaust gases go through turbo before exiting at rear of car, whilst this is all happening the crank goes round and round like the wheels on a bus and, via the flywheel which is now spinning with the clutch bolted to it which has a shaft that is part of the gearbox through the middle of it, drive is finally put to the wheels.
So, If you had the exact same set up on a stroked engine and a 2 litre one of them is getting more air into it which will go bangdiddy-bang-bang bigger due to the larger amount of air/fuel mix which will get the turbo spooling lower down the revs which means you will make power earlier...
come on jp, we're all rooting for ya...which one makes power sooner
also not many R's have been stroked either here or America (sx conversions) which I think tells me money is better spent elsewhere.
people dont want to stroke them due to the cost of the crank, thats the only reason there aren't more.
With the new darton liners and larger bores being possible you can now get 2.2 without spending 2k on a crank, with the short stroke and larger bore you can still rev nice and high so it will make a very good set up, will be interesting to see how stu and a few others get on.
