pulsarboby said:
i hate to say it but i totally disagree with the above!
i had a car in a while back with 300mm discs, braided lines and standard calipers, and i could feel no difference in the stopping power at all.
when the car was broke i sold the discs etc to a local lad, and told him the truth about them making zilch difference, but he just wanted them as they looked better!
after fitting them, he agreed with me and could see no benefit in the braking at all.
the only benefit you will see with bigger discs, is the fact that they will disperse heat quicker than the smaller ones, which will see slight gains on the track, due to a longer period before brake fade will occur, they will not effect stopping power!
the thing that effects your stopping power is the calipers more than anything else, as you have twice the amount of little men pushing the pads onto the disc, 6 pots will give you triple the amount of little men
pads as previously stated will also add to braking efficiency, but still wont get the full benefit of those pads untill you have more little men pushing them and making them work harder.
but if you go to big with calipers (6 pot and above) you will then also need to uprate your master cylinder, as that wont be man enough to work the little men, and will eventually blow a seal, especially if you have braided lines fitted.
like everything with cars, you get what you pay for! and no good doing half a job as it will bite you in the ass lol
but imho really cant see the point (other than looks) of just using bigger discs on a road car!
That is interesting Bob as, I felt a big difference in the stopping power with the larger discs.
The idea behind the larger disc is that you move the caliper further out from the hub. This will give a much better lever effect and so, improve stopping power, regardless of piston number. Of course, as you've touched on, they will also dissipate heat more effectively.
The idea behind the multiple pistons, is to spread the pressure put on the pad, when you apply the brakes. So, with 4 smaller pistons, you're spreading the pressure more evenly over the entire back of the pad which, in turn, will put more even pressure to the whole friction surface, on to the disc. This will use more of the pads friction surface, more effectively.
With the OE single piston caliper, you're only putting pressure on the centre of the pad so, effectively not using the whole of the pads friction surface to it's maximum.
With 6 piston calipers, you're spreading the pressure across the pad even more effectively so, the pad will again, work even better.
You shouldn't expect any more braking power with multiple piston calipers as, there won't be any. They don't apply any more effort, again, it's the distancing of the caliper from the hub centre that will give you more power.
If you're just after reducing brake fade, the component that is most to blame for this is the pad as, it's brake gases made by the pad, that get trapped between the pad surface and disc surface that cause fade.
The best way to get round this is to get high temp pads and bed them in properly. Getting the discs cross drilled will also help eliminate fade as, the cross drilling allows this gas to escape.
Grooving the disc may also help but, it won't be as effective as cross drilling them but, will be better at cleaning the pad surface, if they're glazed etc...
