H
heaven is a gtir (bry)
Checked the cam timing yesterday and is fine.
Ignition timing is fine too.
Leads are on in the right order and brand new.
Rotor arm is right and brand new.
Brand new fuel filter.
No boost leaks.
Fuel pressure is coming through but cannot do a pressure test as we dont have the equipment. Took the fuel line off and turned the ignition on and it sprayed out.
New walbro fuel pump going on tomorrow.
How is the best way to check the turbo?
i hope that hasnt gone. Im fed up with spending the money on it at the moment.
Will do a compression test on monday but should be fine as i have just done the piston rings.
Is there a way of testing the fuel pressure regulator?
Bry
No boost leaks.
Bry
