Bag of sh1te.
  • Thread starter heaven is a gtir (bry)
  • Start date
H
Checked the cam timing yesterday and is fine. :D
Ignition timing is fine too. :D
Leads are on in the right order and brand new. :D
Rotor arm is right and brand new. :D
Brand new fuel filter. :D
No boost leaks. :D
Fuel pressure is coming through but cannot do a pressure test as we dont have the equipment. Took the fuel line off and turned the ignition on and it sprayed out. :D
New walbro fuel pump going on tomorrow. :D
How is the best way to check the turbo? :oops: i hope that hasnt gone. Im fed up with spending the money on it at the moment. :cry:
Will do a compression test on monday but should be fine as i have just done the piston rings. :D
Is there a way of testing the fuel pressure regulator? :oops:
Bry :D
H
Changed the fuel pump today and there was no differance in the performance. :cry:
Got to check the turbo and fuel regulator tomorrow now. Then i have run out of ideas. :cry:
Bry :D
