skiddusmarkus said:
So the controller isn't really necessary if you have a laptop then?Especially as you seem to be able to access more stuff with one.
As an aside,I've heard if you remove the commander,it acts as an immobiliser as you can have revs set really low so it will stall car if someone tries to drive it off.Anyone know about this?
no,the commander isn`t required if you have the software.
with the commander you don`t map in real time,you`re actually mapping off of a trace.with the software you can map in real time which will allow you to adjust the map while you`re driving and be able to feel the difference immediately.
the commander allows you to access and adjust any feature of the fc.if you had the commander with you,you could lower the rev limit to 2000rpm if you wanted.then,when you come back to the car,reset it again.
bit of a pain in the a%se doing that all the time tho.
btw,sam says you are special case as you are a "special" friend of mr gannon :shock: :shock: :shock:
