2 things to ask
4,172
71
48
Southport - Not Tokyo :-(
Here is the FC commander manual for the RX7. 95% is the same and any questions for what you need are easy to answer.
The PFC manual I recall said disconnect battery, swap ECU, reconnect battery, not very helpful.
The sensor page and options page is where you will spend most of your time
  • Like
Reactions: Cathode
4,172
71
48
No problem, it will give you a feel for all the options.
PFC is quite an old design nowadays. 15 years ago there was a lively modding community with Datalogit that opens up all the hidden features and allows you to self map more easily.
The standard options will take it to 480 hp and by re-calibrating a larger MAF it will go to 600hp. I did all my own mapping from scratch with the PFC as I learnt different strategies to tuning the car for performance and daily running/economy 365 days a year.
What turbo/injectors will you be you running
  • Like
Reactions: Cathode
Cathode
414
100
28
St.Neots
I'll be running 550 Evo injectors and a Garrett 2871R. the current chipped ECU I have is mapped upto 1.2 bar hooked up to a blitz boost controller. But I think it'd be wise to just run standard boost pressure on a fresh rebuild while running in.
If there is a way to send the file, the wife speaks and can read Japanese. So, she'll have to translate.
Cathode
414
100
28
St.Neots
Actually Campbell, I'll have a look through the PFC manual you posted up previously first. I'm sure that'll more than likely fill in most of the blanks foe me :)
Cathode
414
100
28
St.Neots
So, if I bought the R35 MAF, does the MAF connector from the Pulsar plug straight into it without any buggering about whatsoever? None at all? I know I shouldn’t dare to think that it wouldn’t but maybe just maybe, someone will quote me happy.
4,172
71
48
Hi Cathode, I doubt that it will be plug and play, the z32 I used required the loom to be cut and the new plug soldered in. Not a big job but something to consider.
Good idea to run standard boost whilst running in and sorting out flaws in the map.
Cathode
414
100
28
St.Neots
As I suspected! But as you say , not a big job. I’m no stranger to a bit of soldering so no probs. Thanks for the heads up Campbell. Much appreciated. If I don’t hear from you before hand, merry Christmas to you and yours.
5,941
164
63
Wondering how I get 8.89mpg?
I also bought the R35 maf, but never found away to wire it up correctly, plus I needed to weld in a mounting for it which was a nightmare.
I may still opt to attempt this next year if I can find out some more information on the wiring for the R35 maf.
However I might just opt for the Haltec system and run a MAP and Audi R8 coils instead!
  • Like
Reactions: Cathode
Cathode
414
100
28
St.Neots
Yowser! Haltech? As in the whole ECU set up? Sorry if I sound green here. Plus R8 coils? Learn something new every day. Is there any write ups about this anywhere?
Cathode
414
100
28
St.Neots
Is the Z32 MAF a straight plug in? I mean just the connection I know it’d need mapping but straight plug compatibility with the pulsar connector?
5,941
164
63
Yeah I use the Nistune system, but I've had a few issues with it in the past and I'd rather upgrade to something more modern that can watch for knock better, allow better sensor feedback, boost control and they offer a simple RNN14 connector plug which makes things much easier.
Plus I can run the R8 coils with it, but I need to look into this in greater detail as I've only seen a few basic guides and videos so far.
Mighty Car Mods launched a video on this Dec 2019 which mentioned about the R8 coils which I had no idea about!
  • Like
Reactions: Cathode
