rear sway bar won't mate up with rear suspension..
Looking at my set up (whiteline arb) it looks like it's a combination of the mounting being in a slightly different place (slightly further round the damper) and the arb is just too short. The hole is even further back than the stiffest hole position on the whiteline arb, ie much stiffer.
@gtirx2. Your car is in the air so your suspension has dropped, you might find those angles look better once the car is on the floor. As Carl says, it looks like the mounting bracket is too low on the coilovers.
@DJ, I doubt anything will fail or break but you might find it is jamming so making it super stiff at the rear.
djdoc360
Well at least my turn in has improved and my under-steer has decreased. Im going to play around and experment some more to see if i can improve this mod.
