Fire & skill said:early HKS EVC, Profec B, Blitz DSBC, blitz sbc id-3.
personally - buy a profec b, its simple and a great bit of kit
1bar ????olliecast said:high boost
olliecast said:(if there`s any confusion in my post. By, (in the title) "simple boost contoller" i mean one without loads of settings. i want high boost and low boost. I`ll be fitting then getting the afr checked immediately. I`m not looking for a cheap mod, just a good controller, with the ability to give differing boost levels consistantly and accurately).
ashills said:yep lsd viscous centre diff same as rear you should know that by now rob lol
If i am not mistaken a "plated diff" would be a clutch type, some even call it "mechanical type". Cusco does one for our rear diff.Odin said:I knew it was a viscose diff, Just wasn't sure how it was classed, It's not like a proper plated diff is it ;-) .
You misunderstood my reply :doh: .Keira said:neither is any other viscous diff :der: that's why they're called viscous :lol:
I don’t think you can put a "Proper" to any type of LSD. There are many type of LSD technologies, whether its electronic, viscous, clutch or torsen, they all in a way or another limit the slip between the output shafts.youngsyp said:I always thought a helical gear diff was the 'proper' LSD ?! :lol:
That's it mate. Horses for courses.Trip said:I don’t think you can put a "Proper" to any type of LSD. There are many type of LSD technologies, whether its electronic, viscous, clutch or torsen, they all in a way or another limit the slip between the output shafts.
youngsyp said:Rob, the viscous diff, as with any diff will work the same regardless of whether it's in the centre, rear or front. It's simply distributing torque/drive between two axles. ;-)
All my diffs use the same. Silkolene Syn 5. ;-)Odin said:I would of thought that the centre diff maybe had a different thickness/grade of fluid :? .
I meant inside the diff it's self of cause and not the oil that goes in the casing :roll: :doh: , Different fluids give different response's, Well that's my understanding anyway.youngsyp said:All my diffs use the same. Silkolene Syn 5. ;-)
The diffs sit in/ are surrounded by the fluid. Their not sealed units on the GTiR ?! At least that's how I understand it.Odin said:I meant inside the diff it's self of cause and not the oil that goes in the casing :roll: :doh: , Different fluids give different response's, Well that's my understanding anyway.
youngsyp said:The diffs sit in/ are surrounded by the fluid. Their not sealed units on the GTiR ?! At least that's how I understand it.
But yes, different fluids will give different responses.
