How to remove / refit Turbo
Trip
The worse part of the head removal is removing the inlet manifold. The rest is plain sailing :)
PulsarLee
hi,Tripp
any tips on removing the timing chain and belts? im worried about this part and messing up the timing.
Cheers,
Lee
Trip
Before removing the cams , turn the crank shaft pulley until you have crank shaft pulley aligned on TDC mark, timing chain marks are alligned with DOT on the cam sprockets.
You need to end up with crank pulley at TDC, inlet cam sprocket at around 10 o'clock and exhaust at 12 with the timing chain marking aligned with the DOT on the sprocket. Its takes a while (turning) to get everything aligned.
PulsarLee
Guys,
Thanks for the step by step guide- was very useful. dont suppose you have a similar guide on how to remove the cams and ensure that the timing isnt affected when removing the head.
Thanks,
Lee
Trip
Guys,
Thanks,
Lee
I have posted a step by step guuide from the manual on your other thread.
